Looking forwards for your thoughts about
![Smile :)](./images/smilies/icon_e_smile.gif)
Available on Tindie: https://www.tindie.com/products/nEXT_EVO1/universal-ac-mains-dimmer-mpdmv41/
Explore... Chat... Share...
forlotto wrote:Ok so we talked a bit about the dimmer as of yesterday one thing I need to refresh myself on is the circuit I believe if I recall correct the VCC required a 5v power and the VCNT was a 0-2.8v more or less. I finally have the board and a little bit of time will be doing some testing to see how everything pans out.
There are a couple of potential things I am curious about The STmicro triac that is bent over this really just needs more separation on the board in my case it is a requirement for it to stand straight up will it be able to dissapate enough heat standing up in an enclosed box or does it need to be bent or have vents and a fan to cool it? Would hate to see this thing melt my case or burn my house down because of improper cooling...
It will also be nice to see how well this device deals with flicker vs the other board if it is indeed flicker free it will be a rather interesting deal.
cls
let pinNo = 5
let Brightness = 890
print "Control PIN"
textbox pinNo
print " Brightness"
textbox Brightness
button " Set Brightness " [SetBrightness]
button " Exit " [TestExit]
wait
[SetBrightness]
pwo pinNo Brightness
wait
[TestExit]
cls
let pinNo = 5
print "Control PIN"
textbox pinNo
print " Brightness"
textbox Brightness
wait
[SetBrightness]
io(pwo,pinNo,Brightness)
wait
[TestExit]
