connect {SSID}, {password}
I've tried countless variations but I cannot get it to connect to my router (unless through luck when I reboot as I have the SSID and Password set in the Station Mode settings.
When it fails on power up it prints ESP Basic 3.0 Alpha 13 then the numbers 1 to 12 each on a new line and then it says
12
Failed Wifi Connect
Creating WIFI access point
ESP_Test
APname
APpass
Ideally I'd LIKE it to connect to the router on every power up but it's hit and miss as to if it connects or creates an Access point.
I can live happily without it connecting on power up IF I can get the program itself to connect when it's running
4 questions if anyone can help
1 How EXACTLY do you type/use the CONNECT command?
It is CONNECT SSID PASSWORD? or CONNECT SSID, PASSWORD,? or CONNECT {SSID}, {PASSWORD} ? or something else?
2 Is there a way to get it to connect automatically to the router on every power up? Even though I have the SSID and Password in the Station Mode (Connect to your router): boxes it is hit and miss if it connects on power up or creates an access point
3 is there a way to clear the Station Mode (Connect to your router): settings?
If I delete the name and password in there and save or reboot or save and reboot the name and password ALWAYS returns and I cannot get it cleared.
4 - not related to the Connect command -
What is the default baud on the serial port after flashing an updated version of Basic?
EDIT: does it matter that I'm using an ESP8266-01 with the 1M flash?
