- Mon Sep 05, 2016 5:19 am
#54507
Most of my stuff has come from ebay, mainly because ebay gives buyer protection to prevent seller rip-offs.
There's a bit of a trick I've learned for finding the best ebay deals.
I'm an ex-pat Brit living in France, so I would use ebay.co.uk, but the trick is to change the left-hand 'Item Location' from 'Default' to 'Worldwide', so then you will get shown similar listings from the same asian suppliers but posted also on the likes of the Aussie and USA ebays etc, which often offer better prices on the same items because of fluctuating exchange rates and global language misunderstandings.
It doesn't matter to the same asian supplier whether he sends his foreign better-priced listing found on another countries ebay directly to your country instead - he makes a sale that he may not have done otherwise, and you pay less for the same item than you would have if bought from your local ebay. That is assuming that the wanted item was even available on your local ebay, often it might only be available from a different country.
I also change 'Format' from 'All listings' to 'Buy it now' to get rid of all the haggling rubbish.
And I would always click 'Free P&P' in 'Delivery options' when lookinfg for the cheaper stuff...if you can't find what you want with free delivery, you can always unclick it and see what's on offer with paid delivery.
Some pointers about Beam-break sensors...
Some short-range types just bounce an infra-red LED back from a remote reflector and look for the reflection to be interrupted. Others have TX and RX units, but it's still just a simple led beam. Possibly battery driven. Range is typically just a few feet.
Do a 'Worldwide, Buy-it-now, Free-delivery' ebay search for "infra beam sensor" to see what's available.
Better security type beam-breaks will typically use a 12v supply, dual beams, probably through optical lenses, and using coded pulses to improve reliability and range and minimise false triggering from falling leaves etc. Range is typically 10 to 100 metres.
Do the same search as above, but
without Free-delivery, to see what else is available.
