Place to put your Basic demos and examples
By Oldbod
#62569 I'm compiling version 66, using the source from Github, and rel 1.6.5. Thought I'd try and see if beginner's luck might help me find something here. I notice that the compile picks up libraries from more than one place, just wondering if there's a way to check that I've got everything exactly the same as the live build. I do experience the problem, so it's in there somewhere, but just in case......
By Mmiscool
#62585 If u are using windows the libraries folder is located in my docs under the arduino folder. You will get warnings about the libraries but it will uses the one from the my docs folder.
Make sure you copy the libraries from the git hub to that folder to be sure you are working with the same environment.
