Place to put your Basic demos and examples
By dziloo@wp.pl
#63144 I Update The Code for ESP Basic Alpha 3.xx Branch. Working very good !!!
Code: Select all
'For ESP Basic Alpha 3.xx Branch
'The following code will dim an led on pin 2 using a slider control
'This LED is Blue color in NodeMcu board
lightlevel = 0
slider lightlevel, 0, 1023
button "Set level", [set.it]
wait
[set.it]
io(pwo, 2, lightlevel)
wait
By heckler
#63163 Hi dziloo,
If you add this...
timer 200,[set.it]
into the code and then a textbox to show the value it will update the light level automatically. :D
see example below
regards
dwight
Code: Select all'For ESP Basic Alpha 3.xx Branch
lightlevel = 0
wprint "0 "
wprint " 1023"
print " Light Level Now = "
textbox lightlevel
timer 200, [set.it]
wait
[set.it]
wait
- See more at: http://www.esp8266.com/viewtopic.php?f=40&t=6537&start=4#sthash.qFM08C6d.dpuf
