Errr I'm not sure of the voltage at the pin when high during normal operation but you could just keep another pin high at all times grab the voltage from that pin on one leg of your switch then put the pin that is being monitored on the other leg of the switch in theory when it is pressed the pin should register as high. If you want to pull it low then you would use the gnd pin...
But personally at this point you might as well just hook up a light switch in line on the power coming out of the relay as it would be the most effective short of using your smart phone for instance.
Bottom line Bravo great project TIS THE SEASON!
Thank You for sharing have a nice Christmas.
-forlotto
Where I buy my ESP8266 boards from... (Banggood)
