Please do not try this at home without proper knowledge of laws, knowledge of AC, electric and or certifications required to do so! This is only a demonstration and a note for those who are interested in the working! If you do this you must understand USING THIS IMPROPERLY COULD RESULT IN DEATH, SERIOUS INJURY, fines, or loss of property to you or others! It is extremely important that you DO NOT TRY THIS AT HOME! Without the proper working knowledge, and safety precautions. I assume ZERO liability for any use! You have been warned!
WARNING!!!!! MUST READ WARNING!!!!!!!!
button "OFF" [OFF]
button "1" [1]
button "2" [2]
button "3" [3]
button "4" [4]
button "5" [5]
button "fun" [fun]
wait
[OFF]
pwo D4 0
pwo D4 0
wait
[1]
pwo D4 180
wait
[2]
pwo D4 200
wait
[3]
pwo D4 220
wait
[4]
pwo D4 260
wait
[5]
pwo D4 400
wait
[fun]
pwo D4 180
delay 100
pwo D4 200
delay 100
pwo D4 220
delay 100
pwo D4 240
delay 100
pwo D4 260
delay 100
pwo D4 280
delay 100
pwo D4 300
delay 100
pwo D4 320
delay 100
pwo D4 340
delay 100
pwo D4 360
delay 100
pwo D4 380
delay 100
pwo D4 400
delay 100
pwo D4 380
delay 100
pwo D4 360
delay 100
pwo D4 340
delay 100
pwo D4 320
delay 100
pwo D4 300
delay 100
pwo D4 280
delay 100
pwo D4 260
delay 100
pwo D4 240
delay 100
pwo D4 220
delay 100
pwo D4 200
delay 100
pwo D4 180
delay 100
pwo D4 160
wait
Parts List:
Esp Basic Wifi Dev Board: http://www.esp8266basic.com/store/p1/ESP_Basic_WIFI_Dev_Board.html
Lamp Socket: Get it from walmart a porcelin light fixture will work fine
Jumper Wire: Get it from anywhere amazon, ebay etc.
AC Dimmer Board: http://www.ebay.com/itm/221975640949 or http://www.ebay.com/itm/222030612813
Instructions:
Connect to the Basic IDE using your web browser if you need help doing this refer to the link in my signature to get started! The Beginners Guide.
Load the program above to the ESPBASIC DEV Board using the edit page and save it as blank don't enter a name.
Connect Mode Jumper to 3.3v
Connect 5v to Vin
Connect Gnd to Gnd
Connect PWM to D4
Connect Light to AC LOAD Screw Down Make sure it is tight if stranded wire is used be sure no strands are hanging out!
Connect Power plug to AC Screw Down Make sure it is tight if stranded wire is used be sure no strands are hanging out!
Connect USB to power up Basic Dev Board.
Plug Power Plug Into a socket.
Run Program And Enjoy Wifi Dimming from any wifi device made simple!
Be sure to use dimmable CFL or Dimmable LED based bulbs for best results!
UPDATE UPDATE UPDATE:::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::!!!!!!
I have created an android application that will function for AP MODE called dimdum AP MODE ONLY FOLKS keep this in mind it is super simple to create one for wifi if you need it do a little research.
I also have updated my own code so that the light turns on after initial boot so it will turn on to show that everything is powered up then it will turn off and wait 30 seconds to boot. Once booted light comes on so you could in theory just use your light switch albeit the action is delayed. I would also like to note there is a delay not of my own choosing for turning the device to off via the controller board, but I did not worry about this as the delay is actually helpful it is approx 15 seconds giving you 15 seconds to exit whatever room you are in before turning off. I did however update my own code so that the light flashes letting you know that the off command was accepted.
UPDATED CODE:
pwo D4 180
delay 100
pwo D4 200
delay 100
pwo D4 280
delay 100
pwo D4 400
wprint "SET Dimmer <br>"
button "OFF" [OFF]
button "1" [1]
button "2" [2]
button "3" [3]
button "4" [4]
button "5" [5]
button "fun" [fun]
wait
[OFF]
pwo D4 300
delay 100
pwo D4 250
delay 100
pwo D4 180
delay 100
pwo D4 0
wait
[1]
pwo D4 180
wait
[2]
pwo D4 200
wait
[3]
pwo D4 220
wait
[4]
pwo D4 260
wait
[5]
pwo D4 400
wait
[fun]
pwo D4 180
delay 100
pwo D4 200
delay 100
pwo D4 220
delay 100
pwo D4 240
delay 100
pwo D4 260
delay 100
pwo D4 280
delay 100
pwo D4 300
delay 100
pwo D4 320
delay 100
pwo D4 340
delay 100
pwo D4 360
delay 100
pwo D4 380
delay 100
pwo D4 400
delay 100
pwo D4 380
delay 100
pwo D4 360
delay 100
pwo D4 340
delay 100
pwo D4 320
delay 100
pwo D4 300
delay 100
pwo D4 280
delay 100
pwo D4 260
delay 100
pwo D4 240
delay 100
pwo D4 220
delay 100
pwo D4 200
delay 100
pwo D4 180
delay 100
pwo D4 160
wait
Also got in contact with the manufacturer of the dimmer board he has released larger quantity for your ordering pleasure included another link above!!!
Give it a shot let it rip this thing is way better than any dimmer I have seen to date!
Where I buy my ESP8266 boards from... (Banggood)
