As far as i know, if gpio0 is found low, it will go into flash-mode.
If gpio15 is high during boot, it will try to boot from a cf-card.
A led with resistor connected to one of those pins can change the input-level of that pin during a reboot.
I would suggest you to try connecting your led to another gpio-pin to find out if this is the case.
Hope this helps.
There are other GPIO's that should not be used either for ON/OFF
As far as saving programs is concerned you must save and then run the program for the new program to work.
But I am beginning to wonder about this as well save program seems to be giving a lot of people trouble currently.
So far I personally have not seen the save program issue the only thing I have seen is WIFI issues due to both AP and STA mode being on.
Another thing that is not working for me is AP name change.
Take care hope this helps!
Where I buy my ESP8266 boards from... (Banggood)
