Page 2 of 2
Re: Internet service monitor and remote router reset button
PostPosted: Sun Mar 06, 2016 2:52 pm
by grzesiu
Hi santo. I mean is there any signal strength loss when You connnect some device with high current usage?
PostPosted: Mon Mar 07, 2016 12:17 am
by forlotto
Hrmmm very interesting.
As far as interference goes I haven't noticed any and I got my device in a ball of wires basically all 110v.
Nice project though cant wait to see more examples like it learn more stuff every day try to help where I can.
PostPosted: Mon Mar 07, 2016 3:21 pm
by santo
I've only used this configuration for a router that draws less than half an amp. And since the router is nearby, there is no trouble connecting to it. No loss of signal is observed. But honestly, I would not use that small relay for a high current appliance. I would use a larger relay or an SSR. I wouldn't try to pack the ESP in with the relay but would have the ESP in it's own case away from the high voltage circuit. I'm currently working on a remote hot water heater controller. The hot water tank draws about 15 to 20 amps. I'm using a 50 amp SSR in it's own metal ULC and CSA approved metal box/disconnect switch box. The ESP module is in it's own plastic box and only the lines used to trigger the SSR come out of the plastic box and into the metal disconnect box. I'll post pictures once I'm done.
