By forlotto
#55066 Yes of course
thx for pointing that out was not paying close enough attention that I was pasting between quotes when I did not need the quotes.
remove the quotes on the outsides I believe from what mmiscool says like so.
Possibly this should work it may have issues I am not testing just helping solve you can test.
Code: Select all'ESPBASIC V3 A44 ECOSTATcss77 dual statmode
'DB1820S Temp Sensor Data PIN IS D4
'Pin D2 for led or relay output inside
'Pin D5 for led or relay output outside
'edited by forlotto
memclear
cls
let tf = 0
let curr = 0
let outc = 0 'for second temp sensor
let statmode = "TOOHOT"
setp = 19
settemp = 19
let stat = "ON"
let statout = "ON"
let setpout = 19
'cssclass "button", "background-color: #99e6e6;"
cssclass "align-self: center;"
css "test1.css"
wprint "<head>"
wprint "<meta http-equiv='refresh'content='5;URL=/input?'>"
wprint "</head>"
wprint "<body bgcolor='#527a7a'>"
wprint "<table align='center' width='102' bgcolor='lightblue' border='4' cellpadding='1'>"
wprint "<td>"
button "MODE", [NIL]
dropdown statmode, "TOOCOLD,TOOHOT"
cssid htmlid(), "background-color:#008ae6;text-align: center;display:block;width:105px"
wprint "<br>"
wprint "</td>"
wprint "<th</th></table><br>"
wprint "<table align='center' width='150' bgcolor='LIGHTblue' border='2' cellpadding='1'>"
wprint "<td>"
button "FAN IP 77", [NIL]
wprint "<b>"
wprint |<mark style="background-color:yellow;">|
wprint "<center>" & htmlvar(stat) & "</center>"
wprint "</mark>"
wprint "</b>"
'wprint "<br>"
wprint "</td>"
wprint "<th</th></table>"
wprint "<br>"
wprint "<table align='center' width='192' bgcolor='lightblue' border='4' cellpadding='3'>"
wprint "<td>"
wprint "  Dropdown "
dropdown setp, "15,18,19,21,22,23,25,26,27,28,30,32,35,38"
wprint "List"
Button "<B>Trigger Level</B>",[setpt]
textbox setp
cssid htmlid(), "background-color:LIGHTGREEN;text-align: center;display:block;width:170px"
wprint "<center> Current Trigger Level </center>"
wprint "<br>"
wprint "<table align='center' width='200' bgcolor='LIGHTBLUE' border='2' cellpadding='2'>"
wprint "<td>"
button "TEMP-C",[NIL]
cssid htmlid(), "background-color:LIGHTGREEN;text-align: center;display:block;width:120px"
wprint "<b>"
wprint "<center>" & htmlvar(curr) & "</center>"
wprint "</mark>"
wprint "</b>"
wprint "</td>"
wprint "<td>"
wprint "<b>"
button "TEMP-F",[NIL]
wprint "<center>" & htmlvar(tfout) & "</center>"
wprint "</mark>"
wprint "</b>"
wprint "</td>"
timer 4000, [refreshcold]
wait
[on2] ' FIRST SENSOR DB1820S ---------
io(po,d5,1)
let stat = "ON"
wait
[off2] ' FIRST SENSOR DB1820S ---------
io(po,d5,0)
let stat = "OFF"
wait
[setpt]
wprint "<head>"
wprint "<meta http-equiv='refresh' content='5;URL=/input?'>"
wprint "</head>"
wait
[refreshcold]
if statmode == "TOOHOT" then goto [refreshhot]
curr = temp(1) 'curr ' read current temperature for device 1 db1820 SECOND SENSOR
'outc = temp(0) ' outc ' read current temperature for device 0 db1820 FIRST SENSOR
tf = curr * 9 ' Fahrenheit CONVERSON
tf = tf / 5
tf = tf + 32
tfout = outc * 9
tfout = tfout / 5
tfout = tfout + 32
if curr < setp then goto [on2] else goto [off2] 'FAN ON IF CURRENT TEMP < GREATER THEN SETP
wait
[refreshhot]
if statmode == "COLD" then goto [refreshhot]
'cssid htmlid(), "background-color:orange;text-align: center;display:block;width:254px"
tf = tf / 5
tf = tf + 32
tfout = outc * 9
tfout = tfout / 5
tfout = tfout + 32
if curr > setp then goto [on2] else goto [off2] 'FAN ON IF CURRENT TEMP < GREATER THEN SETP
wait
[outcon] ' second db1820s sensor TURN RELAY D5 ON AND STAT ON
io(po,d5,1)
let statout = "ON"
wait
[outcoff] ' second db1820s sensor - TURN RELAY D5 OFF AND STAT OFF
io(po,d5,0)
let statout = "OFF"
wait
[NIL]
wait
By joeman2116
#55067 forlotto,
Just tried the new code - no errors but mark highlighting is not displayed
Thanks
Joe
forlotto wrote:Yes of course
'edited by forlotto
memclear
cls
let tf = 0
let curr = 0
setp = 19
settemp = 19
let stat = "ON"
let statout = "ON"
let setpout = 19
css "test1.css"
wprint "<head>"
wprint "</head>"
wprint "<td>"
wprint "<br>"
wprint "</td>"
wprint "<td>"
wprint "<b>"
wprint "</mark>"
wprint "</b>"
'wprint "<br>"
wprint "</td>"
wprint "<br>"
wprint "<td>"
wprint "  Dropdown "
wprint "List"
textbox setp
wprint "<br>"
wprint "<td>"
wprint "<b>"
wprint "</mark>"
wprint "</b>"
wprint "</td>"
wprint "<td>"
wprint "<b>"
wprint "</mark>"
wprint "</b>"
wprint "</td>"
wait
io(po,d5,1)
let stat = "ON"
wait
io(po,d5,0)
let stat = "OFF"
wait
[setpt]
wprint "<head>"
wprint "</head>"
wait
[refreshcold]
tf = tf / 5
tf = tf + 32
tfout = outc * 9
tfout = tfout / 5
tfout = tfout + 32
wait
[refreshhot]
tf = tf / 5
tf = tf + 32
tfout = outc * 9
tfout = tfout / 5
tfout = tfout + 32
wait
io(po,d5,1)
let statout = "ON"
wait
io(po,d5,0)
let statout = "OFF"
wait
[NIL]
wait
By joeman2116
#55068
joeman2116 wrote:forlotto,
Thanks
Joe
NEW CODE:
Thought for a bit and rearranged the code !!
wprint "<center>"
wprint "<mark>" & htmlvar(stat) & "</mark>"
wprint "</center>"
This works - items are centered and have yellow highlighting.
Thanks for yourhelp, Mike and forlotto
I will post new code and screen shot
'edited by forlotto
memclear
cls
let tf = 0
let curr = 0
setp = 19
settemp = 19
let stat = "ON"
let statout = "ON"
let setpout = 19
css "test1.css"
wprint "<head>"
wprint "</head>"
wprint "<td>"
wprint "<br>"
wprint "</td>"
wprint "<td>"
wprint "<b>"
wprint "</mark>"
wprint "</b>"
'wprint "<br>"
wprint "</td>"
wprint "<br>"
wprint "<td>"
wprint "  Dropdown "
wprint "List"
textbox setp
wprint "<br>"
wprint "<td>"
wprint "<b>"
wprint "</mark>"
wprint "</b>"
wprint "</td>"
wprint "<td>"
wprint "<b>"
wprint "</mark>"
wprint "</b>"
wprint "</td>"
wait
io(po,d5,1)
let stat = "ON"
wait
io(po,d5,0)
let stat = "OFF"
wait
[setpt]
wprint "<head>"
wprint "</head>"
wait
[refreshcold]
tf = tf / 5
tf = tf + 32
tfout = outc * 9
tfout = tfout / 5
tfout = tfout + 32
wait
[refreshhot]
tf = tf / 5
tf = tf + 32
tfout = outc * 9
tfout = tfout / 5
tfout = tfout + 32
wait
io(po,d5,1)
let statout = "ON"
wait
io(po,d5,0)
let statout = "OFF"
wait
[NIL]
wait
By joeman2116
#55069 Thanks to forlotto and Mike for your help.
Full code and screenshot
Code: Select all'ESPBASIC V3 A44 ECOSTATcss29 dual statmode
'edited by forlotto
memclear
cls
let tf = 0
let curr = 0
setp = 23
settemp = 23
let stat = "ON"
let statout = "ON"
let setpout = 23
css "test1.css"
wprint "<head>"
wprint "</head>"
wprint "<td>"
wprint "<br>"
wprint "</td>"
wprint "<td>"
button "FAN IP 29", [NIL]
wprint "<b>"
wprint "<center>"
wprint "</center>"
wprint "</b>"
wprint "</td>"
wprint "<br>"
wprint "<td>"
wprint "  Dropdown "
wprint "List"
textbox setp
wprint "<br>"
wprint "<td>"
cssid htmlid(), "background-color:LIGHTGREEN;text-align: center;display:block;width:122px"
wprint "<b>"
wprint "<center>"
wprint "<mark>" & htmlvar(curr) & "</mark>"
wprint "</center>"
wprint "</b>"
wprint "</td>"
wprint "<td>"
wprint "<b>"
wprint "<center>"
wprint "<mark>" & htmlvar(tfout) & "</mark>"
wprint "</center>"
wprint "</b>"
wprint "</td>"
wait
io(po,d5,1)
let stat = "ON"
wait
io(po,d5,0)
let stat = "OFF"
wait
[setpt]
wprint "<head>"
wprint "</head>"
wait
[refreshcold]
tf = tf / 5
tf = tf + 32
tfout = outc * 9
tfout = tfout / 5
tfout = tfout + 32
wait
[refreshhot]
tf = tf / 5
tf = tf + 32
tfout = outc * 9
tfout = tfout / 5
tfout = tfout + 32
wait
io(po,d5,1)
let statout = "ON"
wait
io(po,d5,0)
let statout = "OFF"
wait
[NIL]
wait
