By forlotto
#48894 SKIP TLDR
By forlotto
#48896 ok talked to mike I forgot about this... there is a little fix for issues like this called encompasing data
take your code instead of using ' use " and encompass data like so
using | | symbols
for instance
wprint  | <body bgcolor="blue"> |
By joeman2116
#48951
forlotto wrote:ok talked to mike I forgot about this... there is a little fix for issues like this called encompasing data
using | | symbols
for instance
forlotto,
I tried the format but still no better results.
No background color .
No box / tables worked.
There were no errors but there was no change.
USing the old code In ver 2, background color works and tables / boxes work with colors etc
I think we need the developer to step in and help us with a working example.
joe
By Mmiscool
#48952 There was a major problem with the 3.0 alpha 5.
Just put out a new build
Here is a simple example that dose not use a button to set the temperature. Just type a new value in the target temp field and click off of it or hit tab.
Code: Select allmemclear
SERIALPRINTLN "restart page"
cls
curr = 0
setp = 30
stat
Print "ESP8266 WiFi Thermostat "
print "Target temp="
textbox setp
print "CurrTemp="
textbox curr
print "Heater="
textbox stat
print
button "Exit", [quit]
timer 5000, [refresh]
wait
[refresh]
curr = temp(0)
SERIALPRINTLN curr
if curr < setp then
  io(po,16,1)
  stat = "On"
  io(po,16,0)
  stat = "Off"
end if
Wait
[quit]
timer 0
wprint "<a href='/'>Menu</a>"
