Page 4 of 5
Re: Bug hunt
PostPosted: Thu Sep 21, 2017 10:08 am
by Electroguard
If you watch the serial monitor during a Save you will see the interpreter has a nervoud breakdown and reboots, but presumably it's expected behaviour, because it picks itself up after the reboot and tries to carry on as if nothing had happened.,, and often will confirm a 'succesful' save.
In the early stages it may not always cause corruption, but as the symptoms worsen, so does the corruption. Sometimes it may just be an odd wrong character that is difficult to spot, other times whole chunks of the script may be lost, and sometimes ALL the script is lost.
By now you should know you need to be copying and pasting your script to computer before doing a Save.
So if you are suffering obvious problems every time, try clicking Edit after saving the script, then it will reload the saved script contents back from the ESP and let you compare it to what it should be.
Which all goes to prove that the problem lies with the interpreter cocking up the Save and causing the saved contents to be corrupted - therefore things will obviously go wrong if you try to run the corrupted script, because the damage has already been done.
The boat has a leak, The more you load it, the worse the leak.
Your only realistic option for keeping it afloat is to lighten the load by jettisoning everything overboard that is non-essential... basically your only choice is whether to go down in style, or struggle to stay afloat to complete the journey.
Re: Bug hunt
PostPosted: Sun Sep 24, 2017 5:46 pm
by russm
Just a question, has anyone tried to create a very large comment file with just a few lines of code to determine if it is a pure file save size problem? Just wondering, I will probably give it a try with the latest version. I haven't been very active for a while and find myself with a little (needed) time with electronics. :)
russ
Re: Bug hunt
PostPosted: Thu Nov 30, 2017 4:45 am
by Oldbod
Been away for quite a while. Is this still a problem please?
Re: Bug hunt
PostPosted: Fri Dec 01, 2017 8:36 am
by heckler
I believe this IS still a problem as there have not been any new versions of the OS released.
However I have found that once you get a script working, at least for me, it seems to work perfectly without ongoing issues (assuming you don't have any code bugs)
I have had a freezer alarm working for many months without issue.
regards
dwight
