Report Bugs Here
Moderator: Mmiscool
By xtal
#33076 your code extract eer form eerfh20
I want to extract 20 to change refresh count, I thru the e's in to test instr, I keep getting 0 not 2/3
Why the end after the code ??
using rfh without quotes , how would you use a var then ??
By Mmiscool
#33077 using the quotes is proper form. Right ow the interpreter assumes if variable name has not been used yet that it is a string.
The below code also works.
Code: Select allmycommand = "eerfh20"
x = instr(mycommand,"rfh")
z = x + 3
y = mid(mycommand,x,z)
SERIALPRINTLN mycommand
SERIALPRINTLN x
serialprintln y
end
By Mmiscool
#33088 Uploaded a new build fixing problems in mid() left() and right() functions.
The below code seems to be working.
[top]
cls
textbox mycommand
button "Submt" [myBranch]
wait
[myBranch]
x = x + len("rfh")
z = x + 2
print y
wait
