By bugs
#55152 When my programs start they connect to the network and retry if there is a problem.
What I would like, is access to the Ping command so that I can set the timer to ping the router or access point every 10 seconds so that I can recover from a network component having a short failure e.g.
Code: Select allip$ = "192.168.0.1"
timer 10000, [time4ping]
tries = 0
[connloop]
 tries = tries+1
 if tries > 5 then reboot
 ok = wifi.connect(.........)
 if not ok then goto [connloop]
[mainloop]
do
 if not pingok then goto [connloop]
'the main program
loop until 0
[time4ping]
 pingok = ping(ip$)
return
I have not used the AT+ping command but think it might return a ping time in ms - not sure how difficult it would be to add Ping to BASIC?
