Chat freely about the open source Javascript projects for ESP8266
By xtal
#33489 Looks ok ,, I was giving up because I didn't see any espruino message like your video shows
Thx I've got something new to play with....
Is ther a link to some valid cmds ie mem size etc
By kolban
#33502 Espruino is a JavaScript implementation so any commands or statements that are available in JavaScript can be manually entered for immediate execution or placed in a script for execution as a program. The Espruino web site contains a large number of samples and a quick start - http://www.espruino.com/Quick+Start
and a reference guide to the API - http://www.espruino.com/Reference
Once you have Espruino installed into the flash memory of your ESP8266, you now have a JavaScript run-time. Your next challenge is to figure out what kind of application you wish to write and then write it in JavaScript. If you don't yet know JavaScript, you can use your new environment as a sand-box in which to practice.
By xtal
#33543 extracted this snip from jankop's post , but can't get it to work , anybody see what the prob is...
I assume it is something to do with the require?
Code: Select allvar ssid = "12345-NETGEAR81";
var pass = "mikeis12345";
var http = require("http");
var wifi=require("wifi");
var ESP8266 = require("ESP8266");
print('Connecting to wifi');
         wifi.connect(ssid, pass,null, function(err) {
    print("Wifi error  ", err);
    var ipInfo = wifi.getIP();
    print("Current IP address is: " +
        ESP8266.getAddressAsString(ipInfo.ip) + ':' +
        ESP8266.getAddressAsString(ipInfo.netmask));
I'm seeing
Connecting to wifi
=undefined
wifi error {"errorcode":3,
"errorMessage":"No Access Point Found"}
Current IP Address is: 0.0.0.:0.0.0.0
How would I display my access points using JS?
