By donhamilton
#5716 I have purchased several ESP8266-7 modules from:
http://www.ebay.com/itm/271661018814
As per his description I connected CH_PD, RST, GPIO0 and GPIO2 together through a 3k3 resister to 3V3.
I do not get the startup message.
I have my solder tacked jumper break off so only CH_PD was pulled up and I get a serial stream from TxD.
But the baud rate seemed to be 13.25 uSEC ( which is not a standard baud rate).
Has this version 7 released any documentation ??
Thanks
By donhamilton
#5749 Today I have found that this module is in BootLoader mode.
I get a message at 75,470 baud at power up:
ets Jan 8 2013, rst cause:2, boot mode:(7,2)
Does the bootloader operate at such a strange baud rate ?
By donhamilton
#5760 I found lots of interesting information about the ESP8266:
https://github.com/themadinventor/esptool
I have my ESP8266-7 module working now.
Lots of little things:
GPIO15 must be set to GND at boot up.
GPIO0 must be set to 3V3 at boot up.
GPIO2 must be set to 3V3 at boot up.
Also add a .1 uf cap to REST to GND.
By dontletthesmokeout
#9895 For any others still having issues, it seems a batch with blue power leds and blue Rainsun antennas have the oscillators incorrectly placed. I managed to fix mine with an unregulated iron by eye but a hot air gun would make things much easier.
See viewtopic.php?f=6&t=811&p=8289
