When I start in IOT mode I get the AP that is set up for the client to connect and trigger the portal. I noticed that while I am connected in IOT mode before any config setting are made. Packets do not get received by that AP. This tells me that it's in a loop waiting for setting maybe. After disconnecting and re connecting standalone, no packets.
Missing packets was a due to the sender not closing the UDP client. Not sure how but it looks like that code got reverted to an older commit.
Still connection issues randomly. I started questioning whether I really knew how the ant. should be connected. So I looked it up and I was connecting it wrong. Therefore I had no working 2.4ghz ant.
I am still not sure I have it hooked up correctly.
Antennae Data Sheet http://www.johansontechnology.com/datas ... 43B100.pdf
Attached image shows my current connections. I have not had time to see if this makes a constant difference. I'll let you all know. If you see a problem with the connections though please let me know.
