By mixxx2005
#47914 Hello, I love this cheap way of IoT , but I am new to all this so after tinkering around with different ESP modules some questions rise. So please give me some answers :
1. Is there any issues using Arduino IDE with ESP?
For example I use WiFiClient.ino example to log temperature, but often after 1 - 4 hours it freezes and reset is needed, so is it hardware related or software related issue? I tried same code with NodeMCU , ESP03 and ESP12E modules.
2. Is there any reason to flash new firmware to module,? or if I do not use AT commands and mainly use Arduino IDE - there is no need for that?
Thanks in advance
Greetings from Latvia!! ))
By martinayotte
#47926 The freeze is probably caused by unstable power supply.
Make sure your PSU is strong enough, and add a big capacitor such 100uF nearby the ESP power pins.
No need to upgrade the firmware since the AT Firmware is already gone/erased by having Arduino sketches uploaded.
By xtal
#47937 My experience has been that my arduino code freezes for what ever reason at random intervals, I havn't found a solution.
NodeMCU running very similiar code usually runs until PC is windows updated
By mixxx2005
#48044 Ok, I will try bigger capacitor.
This is my code.
Code: Select all#include <OneWire.h>
OneWire  ds(12);  // on pin 10 (a 4.7K resistor is necessary)
int BL = 13;
float celsius;
const char* ssid     = "xxxxx";
const char* password = "xxxxx";
const char* host = "data.sparkfun.com";
const char* streamId   = "xxxxx";
const char* privateKey = "xxxxx";
  pinMode(BL,OUTPUT);
  WiFi.begin(ssid, password);
void loop(){
digitalWrite(BL,HIGH);
delay(100);
digitalWrite(BL,LOW);
celsius = celsius +1;
sent();
delay(2000);
void sent(){
  WiFiClient client;
  const int httpPort = 80;
       return;
  // We now create a URI for the request
  String url = "/input/";
  url += streamId;
  url += "?private_key=";
  url += privateKey;
  url += "&temp=";
  url += celsius;
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  int timeout = millis() + 1000;
  while (client.available() == 0) {
    if (timeout - millis() < 0) {
           client.stop();
      return;
  while(client.available()){
