- Sat May 28, 2016 4:14 pm
#48175
I got an ESP hooked up to my arduino, and I can control it over a serial terminal from my laptop, but when I try to control it with an arduino program it does nothing. The little blue LED flashes every time I send a command to it from the laptop, but when the arduino sends commands the blue LED doesn't ever light up. Since It's hooked up to the arduino all the time and I'm simply holding the reset button when I want to send commands from my laptop, I know that the problem isn't a loose connection or swapped rx/tx or a similar hardware issue. Any advice? Here's my arduino code:
#include <Wire.h> // Serial library
Serial.begin(115200); // Communication with ESP8266 via 5V/3.3V level shifter
Serial.setTimeout(5000); // Set the timeout value for the ESP8266
delay(5000); // Delay to complete setup
Serial.println("AT"); // Send "AT" to the ESP 10 times/second
delay(100);
