- Wed Jun 22, 2016 1:41 pm
#49618
martinayotte wrote:You're right ! I've answered too quickly thinking about ESP in general.
Then, it could be a power supply issue, because tying RST to GPIO16 should not be the cause.
(BTW, tying them with direct wire will prevent you from doing external reset or uploads during deepSleep(), it is better having a 470R between them or a schottky diode)
I've found that if I made D0 an output pin in setup(), and then digitalWrite(16,HIGH), it wont' reset constantly. But then the moment it goes to sleep and then waits the 10 seconds for the ESP.deepSleep call, it wakes up, and that pin must go to LOW out of sleep and it just keeps resetting again.
So a bit of progress. I know that the D0 pin goes LOW when it comes out of sleep. It never gets to execute setup(), so it stays low and constantly resets. I've also tried putting a capacitor over the GND and 3.3V line, and I still get the constant resets when D0 is connected to RST.
