Have you seen the new AI low cost module?
http://www.aliexpress.com/item/1pcs-Sma ... 20695.html
It isn't yet compatible with Arduino IDE and only works with AT commands, but it's a nice new addition to IoT stuff!
Explore... Chat... Share...
martinayotte wrote:This is not new !
Also, BTW, you can not do any programming with those, the AT firmware included is strictly to do GSM dialog/connect.
You still need to have a separate MCU to control them, such as an ESP.
yeti wrote:[Andreas Spiess] had a first look at it:
#66 New Killer Module from AI-Thinkers? The A6 GSM M2M Module
