Write/Read config from/to flash
Posted: Thu Aug 11, 2016 3:00 pm
Hi all,
I would write the wifi config to flash and read this after reboot.
I've found a read/write example and it's working
Output:
Now, I've written this
Output:
I think, that the result "\0x01\0x08\0x10" is not correct?
Can someone write me a example for this?
static void ICACHE_FLASH_ATTR test() {
os_printf("SDK version:%s\n", system_get_sdk_version());
uint32 temp[4]={122323, 13, 14, 15};
uint32 temp1[4]={0};
int i = spi_flash_erase_sector(0x8c);
os_printf("spi_flash_erase_sector: %d\n", i);
int o = spi_flash_write(0x8c000, temp, sizeof(temp));
os_printf("spi_flash_write: %d\n", o);
int p = spi_flash_read(0x8c000, temp1, sizeof(temp1));
os_printf("spi_flash_read: %d\n", p);
os_printf("read :%x, %x, %x, %x\n", temp1[0], temp1[1], temp1[2], temp1[3]);
Output:
SDK version:1.5.4(baaeaebb)
spi_flash_erase_sector: 0
spi_flash_write: 0
spi_flash_read: 0
read :1ddd3, d, e, f
struct wConf{
char ssid[32];
char passwd[64];
struct wConf wifiApConf;
os_memcpy(wifiApConf.ssid, "CO2", 3);
os_memcpy(wifiApConf.passwd, "co2passwd", 64);
uint32 ssidAp[32];
int o = spi_flash_write(0x8c00, (uint32 *)&wifiApConf.ssid, 3);
int p = spi_flash_read(0x8c00, (uint32 *)&ssidAp[0],4);
os_printf("result: %s\n", ssidAp);
Output:
spi_flash_write: 0
spi_flash_read: 0
result: \0x01\0x08\0x10
