I really hope someone can give me a hand with this, it's driving me crazy...
What I'm trying to do is having a esp-12 in AP mode listening to UDP data (in fact, OSC messages) that several other esp-12s in STA mode are sending, for now restricted to one esp-12 sending a LED-toggle message.
The AP server is OK (I think...) and can be accessed from e.g. Processing (see below) or Packet Sender (Mac), but I just can't get the 2nd esp-12 to connect to the AP server. No errors are shown.
All IP addresses are static and I'm using the Adruino IDE (1.6.11)
After having read a lot on this topic and tried even more, my last hope is the wisdom of crowds... so, any help is hugely appreciated!
AP Server
#include <WiFiUdp.h>
#include <OSCMessage.h>
#include <OSCData.h>
#include <DNSServer.h>
#define BUILTIN_LED 12
#define PACKET_LED 5
const byte DNS_PORT = 53;
WiFiUDP Udp;
DNSServer dnsServer;
const IPAddress local(11, 11, 11, 11);
const IPAddress dns(11, 11, 11, 11);
const IPAddress gateway(11, 11, 11, 1); /* not used */
const IPAddress netmask(255, 255, 255, 0);
const unsigned int localPort = 8888;
OSCErrorCode error;
unsigned int ledState = LOW;
void setup()
pinMode(BUILTIN_LED, OUTPUT);
pinMode(PACKET_LED, OUTPUT);
digitalWrite(BUILTIN_LED, ledState);
digitalWrite(BUILTIN_LED, HIGH);
dnsServer.start(DNS_PORT, "*", local);
WiFi.mode(WIFI_AP);
WiFi.softAPConfig(local, dns, netmask);
WiFi.softAP("UDP-RECEIVER");
WiFi.begin();
Udp.begin(localPort);
void led(OSCMessage &msg)
ledState = msg.getInt(0);
Serial.print("/led: ");
Serial.println(ledState);
void loop()
dnsServer.processNextRequest();
delay(0);
OSCMessage oscMsg;
int size = Udp.parsePacket();
if (size > 0)
Serial.print((String)"Request from " + Udp.remoteIP().toString() + ", port " + Udp.remotePort());
// short blink to show some data was received
digitalWrite(BUILTIN_LED, LOW);
delay(50);
while (size--)
oscMsg.fill(Udp.read());
if (!oscMsg.hasError())
oscMsg.dispatch("/led", led);
error = oscMsg.getError();
Serial.print("error: ");
Serial.println(error);
STA client
WiFiUDP Udp;
int led = 1;
const IPAddress local(11, 11, 11, 30);
const IPAddress server(11, 11, 11, 11);
void setup()
pinMode(5, OUTPUT);
digitalWrite(5, HIGH);
WiFi.mode(WIFI_STA);
WiFi.config(local, dns, netmask);
WiFi.softAP("udpsender1");
//WiFi.config(local, dns, netmask);
WiFi.begin();
void loop()
OSCMessage msg("/led");
msg.add(led);
led = !led;
digitalWrite(5, LOW);
delay(50);
Udp.beginPacket(server, 8888);
msg.send(Udp);
Udp.endPacket();
msg.empty();
delay(1000);
Processing:
import oscP5.*;
import netP5.*;
OscP5 osc;
NetAddress esp8266;
boolean pressed = true;
void setup()
osc = new OscP5(this, 12000);
esp8266 = new NetAddress("11.11.11.11", 8888);
size(100, 100); // click in this square to send an OCS message
void draw()
if (mousePressed)
OscMessage msg = new OscMessage("/led").add((pressed)?1:0);
osc.send(msg, esp8266);
pressed = !pressed;
delay(250);
