http://arduino.stackexchange.com/questions/30386/esp01-connected-to-arduino-cant-publish-mqtt
Explore... Chat... Share...
martinayotte wrote:As mentioned in responses, Arduino UNO is NOT able to provide more than 50mA on 3.3V pin !
The fact that it is working on most of USB-TTL is that those one can deliver more than 300mA.
So, you should use the same 5V of the Arduino, add a 3.3V regulator along with big capacitor such 100uF or even 220uF attached nearby the ESP VCC pins.
