By MolsonB
#57173 I have HUZZAH ESP8266 from Adafruit, using it as an access point with 3 android devices connected to it. The ESP is just streaming data (500bytes x 3 times a second) from an Arduino, receiving the odd command back from the tablets.
Using multicast (x.x.x.255) to send the data to all the tablets, create huge packet loss.
Samsung Tab A 7.0 SM-T280 (2016) > 30%
Samsung Galaxy S5 (2014) > 10%
Samsung Tab 10.1 P7500 (2010) > 4%
Switch to unicast (x.x.x.100) and that one device has very very min packet loss (< 0.5%), but ofcourse only 1 tablet gets updates. Anyone have any idea what to do?
#include <WiFiUDP.h>
#include <ESP8266WebServer.h>
#include <DNSServer.h>
/* Set these to your desired credentials. */
const char *ssid = "xxx";
const char *password = "xxx";
const unsigned int MAX_INPUT = 512;   // how much serial data we expect before a newline
const byte   DNS_PORT  =   53;                                  // Capture DNS requests on port 53
unsigned int localport = 8888;                                   // local port to broadcast on
IPAddress    apIP(10, 10, 10, 1);                               // Private network address: local & gateway
IPAddress    broadcastIP(255, 255, 255, 255);
char        packetBuffer[UDP_TX_PACKET_MAX_SIZE];              // (wifiudp.h 8192) buffer to hold incoming packet,
char        serialBuffer[MAX_INPUT];
String       responseHTML = ""
                      "<!DOCTYPE html><html><head><title>MyPlane_Portal</title></head><body>"
                      "<h1>MyPlane WiFi</h1><p>You are connected to your Plane's BCM</p></body></html>";
DNSServer         dnsServer;                                    // Create the DNS object
WiFiUDP           UDP;                                          // UDP protocol on STA interface, localPort
ESP8266WebServer  webServer(80);                                // HTTP web server on common port 80
void setup()
  Serial.begin(38400);
  WiFi.mode(WIFI_AP);                                           // AcessPoint
  WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));   // IPAddress local_ip, IPAddress gateway, IPAddress subnet
  WiFi.softAP(ssid, "", 6);  //max connection 4 ESP8266WiFi.h
  // replay to all requests with same HTML
  webServer.onNotFound([]() {webServer.send(200, "text/html", responseHTML);});
  webServer.begin();
  // original unicast UDP
  while (! UDP.begin(localport) ) {                             // UDP protocol connected to localPort which is a variable
    yield();                                                    // Play nicely with RTOS (alias = delay(0))
  }                                                             // This will loop forever if UDP fails
void loop()
  static unsigned int input_pos = 0;
  dnsServer.processNextRequest();
  webServer.handleClient();
  //Passes data along
  if (Serial.available() > 0) {
    byte inByte = Serial.read();
    if (inByte == '\n') {           // end of text
      serialBuffer[input_pos] = 0;  // terminating null byte
//      UDP.beginPacket(IPAddress(10,10,10,101), localport);
//      UDP.beginPacketMulticast(IPAddress(10,10,10,101), localport, WiFi.localIP());
//      UDP.beginPacket(IPAddress(10,10,10,255), localport);
      UDP.beginPacketMulticast(IPAddress(10,10,10,255), localport, WiFi.localIP());
      UDP.write(serialBuffer);              // read one character
      UDP.endPacket();                      // clear UDP buffer
      delay(10);
      // reset buffer for next time
      input_pos = 0;
    else if (input_pos < (MAX_INPUT - 1)) {
      serialBuffer[input_pos++] = inByte;
  int packetSize = UDP.parsePacket();                         // if there’s data available, read a packet
  if (packetSize) {
    int len = UDP.read(packetBuffer, MAX_INPUT);              // read the packet into packetBufffer
    if (len > 0) {
      packetBuffer[len] = 0;
    Serial.write(packetBuffer);
    // send a reply, to the IP address and port that sent us the packet we received
    UDP.beginPacket(UDP.remoteIP(), UDP.remotePort());
    UDP.printf("OK%u", packetSize);
    UDP.endPacket();
By MolsonB
#57256 Great read! Thanks for that. Exactly what I'm finding, multicast over wifi is not a good idea trying to stream data. Since the ESP8266 can only allow 4 devices to connect to it, I'll just send the same packet unicast to the 4 devices. See how that works. Also I'm going to look into MQTT.
