rudy wrote:I have some ESP07 that allow the use of an external antenna. That should give better range but I have not tried it yet. There is a new version ESP07S that might have better performance but I have not received them yet. The ESP07S has 4MB flash where the ESP07 only has 512K (or maybe 1MB, I forget).
When using an external antenna use only an antenna with a short cable. At these frequency cable loss is significant when you increase the length. The is cheap long cables sold out of China. Do not use it as it has very high loss and you would be better using the trace antenna on the board.
Mount the radios high above structures. Generally higher is better. Near the ground is poor.
There are higher gain antennas and that is an option but as I have said, use the shortest cable to connect it. Higher gain antennas are directional.
I am not sure about the extending antenna solution , on this video :
https://www.youtube.com/watch?v=KYLN9qH0C84
extending antenna gave only about 50 meters more then without it .
because of this I have asked about the extending WiFi router devices ...
what do you say ?
