"Blink" example doesn't do anything on my esp8266
Posted: Fri Mar 24, 2017 4:49 pm
I tried to compile and flash the blink example from esp-open-sdk. Compiling and flashing works as expected, without any errors. But the LED is not blinking.
I am using one of these development boards: https://www.aliexpress.com/item/10PCS-L ... 56329.html
The rgb led is always on btw. But I'm expecting the tiny LED on the esp-12e module to blink and it doesn't. It does blink rapidly while flashing though and it also flashes once every time I reset it.
So I installed the Arduino IDE, hoping that it would at least work with that. But no it doesn't. It does flash and compile. But after flashing the LED still doesn't blink.
In addition to that the rgb LED stays dark after flashing with the Arduino IDE. (Not that I care, it's just weird.)
I'm using Linux Mint.
esptool.py v1.2-dev
Connecting...
Auto-detected Flash size: 32m
Running Cesanta flasher stub...
Flash params set to 0x0040
Writing 32768 @ 0x0... 32768 (100 %)
Wrote 32768 bytes at 0x0 in 2.9 seconds (91.8 kbit/s)...
Writing 188416 @ 0x40000... 188416 (100 %)
Wrote 188416 bytes at 0x40000 in 16.3 seconds (92.2 kbit/s)...
Leaving...
