Maybe something else in your code that you didn't tested properly.
Explore... Chat... Share...
I've just tested the SPIFFS.rename() and it is working properly.
Maybe something else in your code that you didn't tested properly. - See more at: posting.php?mode=reply&f=6&t=14299#sthash.w2e538AQ.dpuf
void fileStore() //If 7th day of week, rename "log.txt" to ("log" + month + day + ".txt") and create new, empty "log.txt"
getDateTime();
// rename the file "LOG.TXT"
String logname;
logname = "LOG";
logname += Clock.getMonth(Century);
logname += Clock.getDate();
logname += ".TXT";
SPIFFS.rename("LOG.TXT", logname.c_str());
Serial.println("Gets Here 2");
//For troubleshooting
Serial.println(logname.c_str());
// create a new "log.txt" file for appended writing
File log = SPIFFS.open("LOG.TXT", "a");
if (!log)
Serial.println("file open failed");
log.println("");
log.close();
Serial.println("");
Serial.println("New LOG.TXT created");
// create a file and write one line to the file
SdFile logFile("log.txt", O_WRITE | O_CREAT );
if (!logFile.isOpen())
error("log.txt --new -open");
// rename the file log.txt
// sd.vwd() is the volume working directory, root.
logFileName = "";
logFileName = "log";
logFileName += (RTCTimedEvent.time.month);
logFileName += (RTCTimedEvent.time.day);
logFileName += ".txt";
//Serial.println(logFileName.c_str());
if(sd.exists("log.txt"))
logFile.rename(sd.vwd(), logFileName.c_str());
logFile.close();
exit;
logFile.open("log.txt", O_WRITE | O_CREAT | O_APPEND);
logFile.println("");
logFile.close();
Serial.println("");
// list files
cout << pstr("------") << endl;
sd.ls(LS_R);
Serial.flush();
Serial.end();
