By cardmaker
#66990 For better understand here a log:
10-06-2017 21:05:29.745 [TX] - AT+RST<CR><LF>
10-06-2017 21:05:29.761 [RX] - bcn 0<CR><LF>
del if1<CR><LF>
usl<CR><LF>
<CR><LF>
ets Jan 8 2013,rst cause:1, boot mode:(3,6)<CR><LF>
<CR><LF>
load 0x40100000, len 2408, room 16 <CR><LF>
tail 8<CR><LF>
chksum 0xe5<CR><LF>
load 0x3ffe8000, len 776, room 0 <CR><LF>
tail 8<CR><LF>
chksum 0x84<CR><LF>
load 0x3ffe8310, len 632, room 0 <CR><LF>
tail 8<CR><LF>
chksum 0xd8<CR><LF>
csum 0xd8<CR><LF>
<CR><LF>
2nd boot version : 1.6<CR><LF>
SPI Speed : 40MHz<CR><LF>
SPI Mode : QIO<CR><LF>
SPI Flash Size & Map: 8Mbit(512KB+512KB)<CR><LF>
jump to run user1 @ 1000<CR><LF>
<CR><LF>
mode : softAP(5e:cf:7f:10:bb:3c)<CR><LF>
add if1<CR><LF>
dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)<CR><LF>
bcn 100<CR><LF>
10-06-2017 21:05:54.974 [TX] - AT+CWMODE=3<CR><LF>
10-06-2017 21:05:55.004 [RX] - mode : sta(5c:cf:7f:10:bb:3c) + softAP(5e:cf:7f:10:bb:3c)<CR><LF>
add if0<CR><LF>
10-06-2017 21:06:01.887 [TX] - AT+CWLAP<CR><LF>
10-06-2017 21:06:01.901 [RX] - f r0, scandone<CR><LF>
sta scan trace -28<CR><LF>
10-06-2017 21:06:19.637 [TX] - AT+CWMODE=1<CR><LF>
10-06-2017 21:06:19.655 [RX] - bcn 0<CR><LF>
del if1<CR><LF>
mode : sta(5c:cf:7f:10:bb:3c)<CR><LF>
10-06-2017 21:06:28.971 [TX] - AT+CWLAP<CR><LF>
10-06-2017 21:06:28.988 [RX] - f r-28, scandone<CR><LF>
sta scan trace -29<CR><LF>
10-06-2017 21:06:39.229 [TX] - AT<CR><LF>
10-06-2017 21:06:42.280 [TX] - AT<CR><LF>
10-06-2017 21:06:42.800 [TX] - AT<CR><LF>
10-06-2017 21:06:49.280 [TX] - AT+CIPSTATUS<CR><LF>
10-06-2017 21:06:52.950 [TX] - AT+CIPSTATUS<CR><LF>
10-06-2017 21:06:53.800 [TX] - AT+CIPSTATUS<CR><LF>
10-06-2017 21:07:32.202 [TX] - AT+GMR<CR><LF>
10-06-2017 21:07:34.312 [TX] - AT+GMR<CR><LF>
10-06-2017 21:07:34.731 [TX] - AT+GMR<CR><LF>
as you can AT+CWLAP always responde just scandone and not the list in both modes 1 or 3.
and a few others cmd not responding.
By QuickFix
#66996 @cardmaker: I have to be honoust that I haven't got a clue of what could be wrong. :?
Are you using an ESP-01 (by the looks of your first posts and the log it appears to be) or another model?
Maybe it's a good idea to buy a couple of others (and other models, like the ESP-12 or even a actual development board) to rule out issues with your current board. :idea:
[UPDATE]
Other things you can try:
  • Enter AT+RESTORE: this will restore your ESP to its default settings
  • Enter AT+CWLAPOPT=1,127: this will set all options to show in the AT+CWLAP command
  • Search the forums of Espressif for similar topics
By cardmaker
#67034 Hello, my esp model is this one in this picture:
is the esp8266 001 al-cloud inside
AT+RESTORE this cmd responde and do a reset lyke the AT+RST
thisn one AT+CWLAPOPT=1,127 not repond.
im trying in varius modules because i have many pcs same model.
By QuickFix
#67040 I searched my ESP-module collection and found an older (brand new) ESP-01 (I also have the S-version with optimized PCB layout).
I plugged it into my bread board and it did exactly was it is supposed to do:
Booting @74880 baud directly after reset:
Code: Select all ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x40100000, len 1396, room 16
tail 4
chksum 0x89
load 0x3ffe8000, len 776, room 4
tail 4
chksum 0xe8
load 0x3ffe8308, len 540, room 4
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
  SPI Speed      : 40MHz
  SPI Mode       : DIO
Then it boots further @115200 baud
Code: Select all▒l`▒n't use rtc mem data
r▒9l▒d▒
Ai-Thinker Technology Co.,Ltd.
ready
...and I can enter commands:
Code: Select allAT
OK
AT+GMR
AT version:0.40.0.0(Aug  8 2015 14:45:58)
SDK version:1.3.0
Build:1.3.0.2 Sep 11 2015 11:48:04
OK
AT+CWMODE?
+CWMODE:2
OK
AT+CWMODE=1
OK
AT+CWMODE?
+CWMODE:1
OK
AT+CWLAP
+CWLAP:(3,"UPC248887519",-63,"f8:04:2e:90:eb:88",1,-16)
+CWLAP:(4,"Dionne",-67,"64:27:37:69:8d:d0",3,-29)
+CWLAP:(0,"Ziggo",-65,"66:27:37:69:8d:d1",3,-29)
+CWLAP:(0,"KPN Fon",-83,"6a:b5:7e:25:e6:fa",5,6)
+CWLAP:(3,"H369A25E6F9",-86,"74:b5:7e:25:e6:f9",5,6)
+CWLAP:(0,"Ziggo",-90,"ce:af:78:83:aa:d1",6,-14)
+CWLAP:(3,"UPC249976762",-89,"f8:04:2e:4b:5c:78",6,-46)
+CWLAP:(3,"ziggo-ap-3972819",-91,"d8:b6:b7:a4:bc:f0",6,-16)
+CWLAP:(3,"Astrid",-33,"00:e0:20:8a:38:49",7,-11)
+CWLAP:(3,"H369A89242C",-79,"54:be:53:89:24:2c",9,-9)
+CWLAP:(0,"KPN Fon",-84,"62:be:53:89:24:2d",9,-9)
+CWLAP:(3,"ZiggoD21C4",-86,"ec:55:f9:9c:51:0d",11,-11)
+CWLAP:(0,"Ziggo",-86,"ee:55:f9:9c:51:0e",11,-9)
+CWLAP:(3,"HZN241311850",-86,"54:fa:3e:74:2b:9f",13,-34)
OK
Note, however, that I've used the original firmware that came with it:
Code: Select allAT+GMR
SDK version:1.3.0
I haven't updated it to the latest version yet; maybe you should try an older firmware version instead. :idea:
[UPDATE]
After having another look at the ESP-matrix, it looks like the ESP-01 can have different size flash memory installed.
Both of my ESP-01's have 8Mbit, while normally it's only 4Mbit in size; perhaps yours are only 4Mbit (though that doesn't explain why you don't have checksum errors at boot). :?
