By faramon
#66030 I have NodeMcu esp8266 v 0.9 and there is wifi and mqtt with relay that is operated with mobile and works as a charm. I buy some 4 aaa battery box with microusb and i want to power nodemcu up with it because i testing it over usb on my computer. How to increase buttery long life to power nodemcu? is this nodemcu little power consumer or not? Can buttery power works for a couple of months? I read about sleep mode but how nodemcu wakes up when mqtt message is sent from smartphone? How this works in general? i can wait until battery falls in power but if someone has the solution for the problem i will be greatfull for advice.
Thanx,
Faramon
By rudy
#66036 WiFi is not a low power device. If the radio needs to be on continuously the power consumption will be significant. It will drain the batteries quickly. If it is to power a relay then that also will add to the power drain. The radio alone would last for less than a day on AAA alkaline batteries based on an average current of 75mA and a battery capacity of 1200mAH.
Bluetooth LE might be a better choice as far as power consumption. It is much harder to work with.
By rudy
#66046 This looks easy http://bleduino.cc/ but I don't know what it costs.
Then there is Adafruit https://www.adafruit.com/product/1697
I have a couple of Bluetooth LE modules but I have not had the time to work with any yet. If you need a relay in your application then you should also look at that as it could be a significant drain on the batteries. Use a Mosfet transistor as a switch if you can.
