By OG Style
#68352 I'm trying to hook up a sensor to my ESP8266-01 but I keep getting "Error compiling for board Generic ESP8266 Module."
I'm using the code from here and I keep getting the error.
https://learn.adafruit.com/esp8266-temp ... erver/code
I am able to compile and upload the code from here without any problems.
http://randomnerdtutorials.com/how-to-i ... duino-ide/
I have been search all day and I can't get it to work. I tried different versions of Arduino IDE and ESP8266 IDE with no luck. Can someone please help me with this issue
By OG Style
#68380 Here's what I'm getting.
Arduino: 1.6.8 (Windows 7), Board: "Generic ESP8266 Module, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS), ck, Disabled, None"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\Owner\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\Owner\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Owner\Documents\Arduino\libraries" -fqbn=esp8266:esp8266:generic:CpuFrequency=80,FlashFreq=40,FlashMode=dio,UploadSpeed=115200,FlashSize=512K64,ResetMethod=ck,Debug=Disabled,DebugLevel=None____ -ide-version=10608 -build-path "C:\Users\Owner\AppData\Local\Temp\build7008b984057a84e07b4e2b3a28c97e26.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Owner\Desktop\ESP\a\a.ino"
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\Owner\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\Owner\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Owner\Documents\Arduino\libraries" -fqbn=esp8266:esp8266:generic:CpuFrequency=80,FlashFreq=40,FlashMode=dio,UploadSpeed=115200,FlashSize=512K64,ResetMethod=ck,Debug=Disabled,DebugLevel=None____ -ide-version=10608 -build-path "C:\Users\Owner\AppData\Local\Temp\build7008b984057a84e07b4e2b3a28c97e26.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Owner\Desktop\ESP\a\a.ino"
"C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Owner\AppData\Local\Temp\build7008b984057a84e07b4e2b3a28c97e26.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "C:\Users\Owner\AppData\Local\Temp\build7008b984057a84e07b4e2b3a28c97e26.tmp\sketch\a.ino.cpp" -o "nul"
"C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Owner\AppData\Local\Temp\build7008b984057a84e07b4e2b3a28c97e26.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "C:\Users\Owner\AppData\Local\Temp\build7008b984057a84e07b4e2b3a28c97e26.tmp\sketch\a.ino.cpp" -o "nul"
"C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Owner\AppData\Local\Temp\build7008b984057a84e07b4e2b3a28c97e26.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src" "C:\Users\Owner\AppData\Local\Temp\build7008b984057a84e07b4e2b3a28c97e26.tmp\sketch\a.ino.cpp" -o "nul"
"C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Owner\AppData\Local\Temp\build7008b984057a84e07b4e2b3a28c97e26.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\generic" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src" "C:\Users\Owner\AppData\Local\Temp\build7008b984057a84e07b4e2b3a28c97e26.tmp\sketch\a.ino.cpp" -o "C:\Users\Owner\AppData\Local\Temp\build7008b984057a84e07b4e2b3a28c97e26.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\Owner\Desktop\ESP\a\a.ino:10:17: fatal error: DHT.h: No such file or directory
#include <DHT.h>
compilation terminated.
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
Using library ESP8266WebServer at version 1.0 in folder: C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer
exit status 1
