By martinayotte
#68447 Try adding some Serial.println() in the setup() to see if it is actually getting there.
Also, add right at the beginning of setup() the command "WiFi.mode(WIFI_STA);".
Another possible thing is to erase the flash chip completely before re-uploading your sketch, using "esptool.py erase_flash"
By rudy
#68449
OG Style wrote:I added the 10k resistor to the RST and I am still getting the same error. I also tried it with a different PSU.
ets Jan 8 2013,rst cause:4, boot mode:(3,7)
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v09f0c112
~ld
Do you have something like a 100uF capacitor? If so then put it across 3.3v and gnd on the breadboard as close to the module pins as you can.
By OG Style
#68453 I put a 100uf cap in and it makes no difference. Here is the sketch I am using. I have my ssid and password field in on my sketch.
/* DHTServer - ESP8266 Webserver with a DHT sensor as an input
Based on ESP8266Webserver, DHTexample, and BlinkWithoutDelay (thank you)
Version 1.0 5/3/2014 Version 1.0 Mike Barela for Adafruit Industries
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <DHT.h>
#define DHTTYPE DHT22
#define DHTPIN 2
const char* ssid = "";
const char* password = "";
ESP8266WebServer server(80);
// Initialize DHT sensor
// NOTE: For working with a faster than ATmega328p 16 MHz Arduino chip, like an ESP8266,
// you need to increase the threshold for cycle counts considered a 1 or 0.
// You can do this by passing a 3rd parameter for this threshold. It's a bit
// of fiddling to find the right value, but in general the faster the CPU the
// higher the value. The default for a 16mhz AVR is a value of 6. For an
// Arduino Due that runs at 84mhz a value of 30 works.
// This is for the ESP8266 processor on ESP-01
DHT dht(DHTPIN, DHTTYPE, 11); // 11 works fine for ESP8266
float humidity, temp_f; // Values read from sensor
String webString=""; // String to display
// Generally, you should use "unsigned long" for variables that hold time
unsigned long previousMillis = 0; // will store last temp was read
const long interval = 2000; // interval at which to read sensor
void handle_root() {
server.send(200, "text/plain", "Hello from the weather esp8266, read from /temp or /humidity");
delay(100);
void setup(void)
// You can open the Arduino IDE Serial Monitor window to see what the code is doing
Serial.begin(115200); // Serial connection from ESP-01 via 3.3v console cable
dht.begin(); // initialize temperature sensor
// Connect to WiFi network
WiFi.begin(ssid, password);
Serial.print("\n\r \n\rWorking to connect");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.println("DHT Weather Reading Server");
Serial.println(ssid);
Serial.print("IP address: ");
server.on("/", handle_root);
server.on("/temp", [](){ // if you add this subdirectory to your webserver call, you get text below :)
gettemperature(); // read sensor
webString="Temperature: "+String((int)temp_f)+" F"; // Arduino has a hard time with float to string
server.send(200, "text/plain", webString); // send to someones browser when asked
server.on("/humidity", [](){ // if you add this subdirectory to your webserver call, you get text below :)
webString="Humidity: "+String((int)humidity)+"%";
server.begin();
void loop(void)
server.handleClient();
void gettemperature() {
// Wait at least 2 seconds seconds between measurements.
// if the difference between the current time and last time you read
// the sensor is bigger than the interval you set, read the sensor
// Works better than delay for things happening elsewhere also
if(currentMillis - previousMillis >= interval) {
// save the last time you read the sensor
// Reading temperature for humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (it's a very slow sensor)
humidity = dht.readHumidity(); // Read humidity (percent)
temp_f = dht.readTemperature(true); // Read temperature as Fahrenheit
// Check if any reads failed and exit early (to try again).
if (isnan(humidity) || isnan(temp_f)) {
return;
