http://www.szcompare.com/detail.aspx?cid=106
http://www.datasheetspdf.com/PDF/RTL8711AF/1046690/1
http://www.ebay.com/itm/New-RTl8711AF-I ... 2035381913
hi
CP830 module is said to deliver up to 150Mbps data rate.
it's available on ebay for about $5, incl shipping.
is based on RealTek RTL8711AF
i cannot find this chip or module on this site or hackaday.
details:
CP830 is a highly integrated module with low power 802.11n Wireless LAN(WLAN) network controller.
It combines an ARM-CM3 MCU, WLAN MAC, a 1T1R capable WLAN baseband, and RF function.
It also provides a bunch of configurable GPIOs which are configured as digital peripherals fordifferent applications and control usage.
CP830 integrates internal memories for complete WIFI protocol functions. The embedded memory
configuration alsoprovides simple application developments.
Size:22.25mm x 19mm x 1.6mm
CMOS MAC, Baseband PHY, and RF in the module for 802.11b/g/n compatible WLAN
Complete 802.11n solution for 2.4G band
150Mbps receive PHY rate and 150Mbps transmit PHY rate using 40MHz bandwidth
Standards Supported
802.11e QoS Enhancement(WMM)
802.11i(WPA,WP2). Open, shared key, and pair-wise key authentication services
WiFi Direct support
WiFi WPS support
Light Weight TCP/IP protocol
WLAN PHY Features
802.11n OFDM
One Transmit and one Receive path(1T1R)
20MHz and 40MHz bandwidth transmission
Short Guard Interval(400ns)
Maximum data rate 54Mbps in 802.11g and 150Mbps in 802.11n
Host Interface
2 x UART
3x I2C
1 x I2S
2 x PCM
2x SPI
1x SDIO Slave
4x PWM
1x ADC and 1x DAC
21 xGPIO
Thoughts?
cheers!
