By Luhan
#69683 That's why I posted here. Is there an easier way to use HTML files that does not require programming? What I have seen is HTML coded in as text strings to a programming language and then loaded into the 8266. Is there any easier way to just use the HTML file 'as is'?
By philbowles
#69916 Is there ANYTHING you can do on the ESp8266 without programming? I'm still confused about what you want to achieve. The most sensible answer is to uses SPIFFS - but that requires programming...
Tell us more about what your REAL question is
