Is it possible ?
Is it possible ?
Explore... Chat... Share...
void showClients()
struct station_info *stat_info;
stat_info = wifi_softap_get_station_info();
uint8_t client_count = wifi_softap_get_station_num();
String str = "Number of clients = ";
str += String(client_count);
str += "\r\nList of clients : \r\n";
int i = 1;
while (stat_info != NULL) {
str += "Station #";
str += String(i);
str += " : ";
str += String(stat_info->bssid[0], HEX);
str += ":";
str += String(stat_info->bssid[1], HEX);
str += ":";
str += String(stat_info->bssid[2], HEX);
str += ":";
str += String(stat_info->bssid[3], HEX);
str += ":";
str += String(stat_info->bssid[4], HEX);
str += ":";
str += String(stat_info->bssid[5], HEX);
str += "\r\n";
i++;
stat_info = STAILQ_NEXT(stat_info, next);
// stat_info = stat_info->next;
Serial.println(str);
extern "C" {
#include "user_interface.h"
