By Pratik_yadav
#70217 Hello,
I have implement esp-gdbstub as per instruction given in Read-me file.
I have made changes related to gdbstub in my make file is as following:
Code: Select all
CFLAGS = -Og -ggdb
GDBSTUBFILES := $(wildcard ./gdbstub_files/*)GDBOBJFILES = $(subst $(GDBSTUBSRC),$(GDBSTUB_BUILD),$(GDBSTUBSRC:%.S=%.o))
GDBOBJFILES += $(subst $(GDBSTUBSRC),$(GDBSTUB_BUILD),$(GDBSTUBSRC:%.c=%.o))
GDBSTUBSRC = $(filter %.c %.S,$(GDBSTUBFILES))
@-mkdir -p $(GDBSTUB_BUILD)
./gdbstub_build/gdbstub_files/gdbstub-entry.o : ./gdbstub_files/gdbstub-entry.S
@echo "this is inside making of gdbstub-entry.o"
mkdir -p $(dir $@)
$(CC) $(CFLAGS) $(INCLUDES) -c $< -o $@
./gdbstub_build/gdbstub_files/gdbstub.o : ./gdbstub_files/gdbstub.c
@echo "this is inside making of gdbstub.c"
mkdir -p $(dir $@)
After changing make file I have include "gdbstub.h" in main file and called gdbstub_init().
To test its working i have created task which generate fatal exception.
I compile my project and flash it into esp8266.
and Hit following command as given by "https://blog.attachix.com/live-debugging-with-open-source-tools-programming-for-esp8266-part-4/"
Code: Select all
xtensa-lx106-elf-gdb -b 115200
(gdb) file out/build/app.out
(gdb) set remote hardware-breakpoint-limit 1
(gdb) set remote hardware-watchpoint-limit 1
(gdb) set debug xtensa 4
(gdb) target remote /dev/ttyUSB0
After Hitting last command my terminal gives following output:
Code: Select all
Remote debugging using /dev/ttyUSB0
Ignoring packet error, continuing...
warning: unrecognized item "timeout" in "qSupported" response
Bogus trace status reply from target: timeout
Is there anything i am missing?
Please help anyone.
