Issue with I2C sensor
Posted: Tue Nov 14, 2017 4:19 pm
Hi all,
I'm having problems with a magnetometer sensor HMC5883 (I2C).
I can detect the sensor with the i2c scanner, but I can't read data: basically it hangs in the getData() method, at mag.getEvent(&event).
I'm using this library: https://github.com/adafruit/Adafruit_HMC5883_Unified
Do you have any suggestion? What can I check?
Let me show you the main loop:
and this is the output:
void displaySensorDetails(void) {
mag.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" uT");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" uT");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" uT");
Serial.println("");
<cut>
Wire.begin(0, 2);
<cut>
displaySensorDetails();
<cut>
void getData]() {
Serial.println("debug 03");
/* Get a new sensor event */
Wire.beginTransmission(address);
error = Wire.endTransmission();
mag.getEvent(&event);
/* Display the results (magnetic vector values are in micro-Tesla (uT)) */
Serial.print("X: "); Serial.print(event.magnetic.x); Serial.print(" ");
<cut>
Serial.println("debug 01");
<cut>
Serial.println("debug 02");
getData();
<cut>
Sensor: HMC5883
Driver Ver: 1
Unique ID: 13
Max Value: 800.00 uT
Min Value: -800.00 uT
Resolution: 0.20 uT
connected to mqtt
debug 01
debug 02
debug 03
