i'm wornking on a smart thermostat with nodemcu and and dht11, the code is developed on the base of various sketches found on the web.
I want to print on the oled screen the variables of temperature and humidity given by dht.
a first sketch works fine:
/ Example sketch for testing OLED display
// We need to include Wire.h for I2C communication
#include <Wire.h>
#include "OLED.h"
#include "DHT.h"
// Declare OLED display
// display(SDA, SCL);
// SDA and SCL are the GPIO pins of ESP8266 that are connected to respective pins of display.
OLED display(4, 5);
#define DHTPIN 14 // PIN DEL SENSORE DHT
#define DHTTYPE DHT11 // DHT 11
// Initialize DHT sensor.
// Note that older versions of this library took an optional third parameter to
// tweak the timings for faster processors. This parameter is no longer needed
// as the current DHT reading algorithm adjusts itself to work on faster procs.
DHT dht(DHTPIN, DHTTYPE);
static char T[5];
static char Hu[5];
Serial.begin(9600);
Serial.println("OLED test!");
dht.begin();
// Initialize display
display.begin();
// Test message
delay(3*1000);
// Wait a few seconds between measurements.
delay(2000);
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
float f = dht.readTemperature(true);
dtostrf(t,3, 2, T);
dtostrf(h,3, 0, Hu);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
return;
Serial.println(h);
Serial.println(t);
display.print(T,1);
display.print(Hu,2);
I've used dtostrf function to convert float to char variable, in order to print them on the oled
it works fine for both t and h
One I put that in a more complex code, the output on the oled shows only T variable but not Hu (humidity).
I can't undestand why.
he code is
//Progetto di termostato "Smart".
//V0.3 29/12/2017
//sketch led adattato da quello pubblicato da STEM su internetofthinking.blogspot.it
//sketch sensore adattato da quello pubblicato da ladyada
//sketch oled adattato da
#include "DHT.h"
#include <Wire.h>
#include "OLED.h"
const char* ssid = "***********";
const char* password = "****************";
OLED display(4, 5);
int relay = 5; // GPIO5 impostiamo il pin del relay
float temp = 17.0;//impostazione iniziale temperatura
int onoff = LOW; //impostiamo la variabile on/off
//dichiaro levariabili necessarie alla scrittura su oled
static char T[5];
static char Hu[3];
static char Temp[4];
WiFiServer server(80);
Serial.begin(9600);
delay(10);
dht.begin();
display.begin();
pinMode(relay, OUTPUT);
digitalWrite(relay, LOW);
// Connect to WiFi network
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// Start the server
server.begin();
// Print the IP address
Serial.print("Use this URL to connect: ");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.println("/");
display.print("Termostato smart",1);
display.print("Versione 0.3",2);
display.print("Created by AP",3);
display.print("Inizialise....",4);
delay(2000);
display.clear();
delay(2000);
return;
//converto le float t e h in stringhe T e H
dtostrf(t,3, 2, T);
dtostrf(temp,2, 1, Temp);
//Scrivere temperatura su display
display.print("T:",1,0);
display.print(T,1,3);
display.print("gradi C",1,9);
display.print("Umidita':",2,0);
display.print(Hu,2,9);
display.print("%",2,15);
//display.print("Temp setted:",3,0);
//display.print(Temp,3,12);
Someone could help me to find a reason for this?
Many thanks
