https://github.com/martin-ger/esp_wifi_repeater
However battery use is high. Is there any way i can put the repeaters into deep sleep mode until needed
Explore... Chat... Share...
rudy wrote:Define "when needed".
Would it be acceptable if you had a 30 second window and a 5 minute off time? (or whatever times you deem acceptable) Remember that when the ESP8266 is in deep sleep it will not respond to any WiFi traffic.
rudy wrote:rudy wrote:Define "when needed".
If you knew when it would be needed (some form of synchronization) then it may be workable.
