thanks
thanks
Explore... Chat... Share...
rebsj wrote:I am interested in using the ESP8266 in a device that will be mobile and roam between multiple Access Points. Is there any information on roaming with the 8266? Does it roam between APs? What triggers roaming? Is there an API that displays known APs and allows the application to control roaming?
thanks
