Hardware: NodeMCU DEVKIT 1.0
Core Version:
Description
Problem description:
Whenever i try to upload any code it shows me this
warning: espcomm_send_command: didn't receive command response
warning: espcomm_send_command(FLASH_DOWNLOAD_BEGIN) failed
error: espcomm_upload_mem failed
Settings in IDE
Module: NodeMCU1.0(ESP-12E Module) ?Generic ESP8266 Module?
Flash Size: 4 M(1M SPIFFS) ?4MB/1MB?
CPU Frequency: 80Mhz
Flash Mode: qio
Flash Frequency:40Mhz
Upload Using: SERIAL
Reset Method: NODEMCU
this is in the examples
Sketch
This sketch demonstrates how to scan WiFi networks.
The API is almost the same as with the WiFi Shield library,
the most obvious difference being the different file you need to include:
#include "ESP8266WiFi.h"
// Set WiFi to station mode and disconnect from an AP if it was previously connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
Serial.println("Setup done");
Serial.println("scan start");
// WiFi.scanNetworks will return the number of networks found
int n = WiFi.scanNetworks();
Serial.println("scan done");
if (n == 0)
Serial.println("no networks found");
Serial.print(n);
Serial.println(" networks found");
for (int i = 0; i < n; ++i)
// Print SSID and RSSI for each network found
Serial.print(i + 1);
Serial.print(": ");
Serial.print(WiFi.SSID(i));
Serial.print(" (");
Serial.print(WiFi.RSSI(i));
Serial.print(")");
Serial.println((WiFi.encryptionType(i) == ENC_TYPE_NONE)?" ":"*");
delay(10);
Serial.println("");
// Wait a bit before scanning again
delay(5000);
### Debug Messages
messages here
any help would be really helpful?
