By olivar1
#33101 Hi,
I tested sending OSC with OSCLib-for-ESP8266, this is really cool
How can I try to receive OSC and parse message ? is trying to adapt the ARDOSC lib would be a good lead ?
My knowledge in building library is very limited....
cheers
Olivar
By hoshy42
#35204 Hi everyone,
i was very delighted to find the OSC library for the ESP, unfortunatly there are some hefty timing/lag issues.
In preperation to connecting a MPU6050 accelerometer, I made this sketch, generating 6 tuples of random data (0-255)
Code: Select all#include <mem.h>
#include <WiFiUdp.h>
#include <OSCMessage.h>
#include <OSCBundle.h>
long sendCount = 0;
const char* ssid     = "mynetwork";
const char* password = "mypassword";
// a instance of UDP  to send and receive packets (udp, oviously!;)
WiFiUDP Udp;
const IPAddress outIp(192, 168, 1, 100);    //ip address of the receiving host
const unsigned int outPort = 9001;              //host port
  // Connect to WiFi network
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  OSCBundle msg;
    msg.add("/X").add((int32_t)(random(0,255)));
    msg.add("/Y").add((int32_t)(random(0,255)));
    msg.add("/Z").add((int32_t)(random(0,255)));
    msg.add("/ax").add((int32_t)(random(0,255)));
    msg.add("/ay").add((int32_t)(random(0,255)));
    msg.add("/az").add((int32_t)(random(0,255)));
  Udp.beginPacket(outIp, outPort);
  msg.send(Udp);
  Udp.endPacket();
  msg.empty();
  delay(100);
it runs smoothly for about 4-6sec then it starts lagging with delays up to 1,5seconds. :shock:
Im reading this with pure-data-extented @ the moment, but you can also see the lag in a network monitor. (e.g. iptraf under linux)
any ideas? Im kind of lost here.....
thx
oli
