If you want to go down the debugger route you may want to try out how promiscous blinky is:
viewtopic.php?f=9&t=3751
Adding some test code to the blinky example,
calling
gdb_breakpoint()
in your callback and then connecting and executing
bt
Cal
Explore... Chat... Share...
gdb_breakpoint()
bt
