rith87 wrote:Hmm.. I added the '-fm dio' option to use 2 data lines instead but I'm hitting another crash now:Code: Select allFatal exception (0):
epc1=0x�, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
load 0x40100000, len 32236, room 16
tail 12
chksum 0x55
ho 0 tail 12 room 4
load 0x3ffe8000, len 2860, room 12
tail 0
chksum 0x30
load 0x3ffe8b30, len 37932, room 8
tail 4
chksum 0xdb
csum 0xdb
��n't use rtc mem data
The last line says "don't use rtc mem data" but I don't see this string in my code or the SDK. Any other ideas? Or is this just a busted batch of ESP-12Es?
I had this problem when I was using a separate power supply for the ESP-12 and the FTDI module (USB Powered) I was using to communicate with the module. After connecting grounds together the module was stable. Hope this helps.
