By annihil8ted
#27543 Hello All!
I was wondering if anyone could help me with my ESP8266-1. I'm interfacing with it using a FTDI FT232RL. After connecting, not matter what commands or baud rate I put in, I couldn't get a response from the module. I then went ahead and downloaded the flasher on this site (https://importhack.wordpress.com/2014/1 ... eb-client/). It kept crashing, giving a message about a failed package. Wouldn't get past 10%. I then switched over to nodemcu. Now when I switched over to nodemcu, things started to work a little. I was able to flash the default .bin file although I'm not exactly sure what that does. There is still no response from the module though when I enter AT. Could someone please point me in the right direction? It would be greatly appreciated! :D
By kenn
#27555
annihil8ted wrote:After connecting, not matter what commands or baud rate I put in, I couldn't get a response from the module. I then went ahead and downloaded the flasher ...
Flashing requires two-way communication, so there's no point to try flashing if you don't have a working connection to the ESP-01.
Best advice I have is to get a factory-fresh ESP-01, and confirm the serial connection by successfully running an AT session, THEN try flashing. Once you've been able to flash, you'll find that your first ESP-01 can be reflashed. They're very hard to brick.
By Kevin Liu
#27590 Thanks Kenn,
I would still try to salvage my existing ESP8266-1 though. I seem to be able to flash nodemcu software so is there anything I could flash to get a reliable communication?
Thanks!
By kenn
#27594
Kevin Liu wrote:I would still try to salvage my existing ESP8266-1 though. I seem to be able to flash nodemcu software so is there anything I could flash to get a reliable communication?
Look in the Espressif SDK (ESP8266_SDK\bin\at), they provide copies of the AT bin files.
