Page 5 of 7
Re: ARP problem
Posted:
Mon Mar 23, 2015 4:24 am
by Aybert
Hey guys I tried the latest V0.95 firmware
I still have the issue with AT+CWMODE=1 (Station) but in reverse it works well with AT+CWMODE=3 (AP+Station)
I can ping my ESP8266 from my LAN and can connect from ESP8266 to any local service
Re: ARP problem
Posted:
Sat Mar 28, 2015 8:03 am
by grooves
I can't confirm, CWMODE = 3 doesn't work for my network scenario, described above,
I tried newest SDK 1.0,
no changes at that issue
Regards,
grooves
Re: ARP problem
Posted:
Sat Nov 28, 2015 6:48 am
by vasimv
I've ran into same problem with Arduino IDE (ESP-12E works but stops sending ARP answers, so everyone on network loses it). To fix this, i'm calling every second function to force send gratuitous ARP announce:
extern "C" {
char *netif_list;
uint8_t etharp_request(char *, char *);
void forceARP() {
char *netif = netif_list;
while (netif)
etharp_request((netif), (netif+4));
netif = *((char **) netif);
Re: ARP problem
Posted:
Thu Apr 21, 2016 7:25 am
by jkroby@p3r.info
Hi,
still not working with dir-300 as access point,
Arduino sdk 1.6.7 esp tool 2.1.0
dir-300 b1 firmware update to 214b01
with other wifi works.
Now dir-300 work well but still not working wit esp8266
When i make first tests it go, i add parts of code based on captiveportaladvanced, one wire, chunked http transmit an so one, when i end, i keep it connected at the net and some times i check thermometer via web.
I update dir-300 (so i solve problems with smartphones and tablets) but still big problems, it loose connection and only in the moment it reconnect, i see it on serial, i can connect with it and when it have problem the softAP don't works at the same way.
Roberto.
