By tytower
#22950
eriksl wrote:If you're using Arduino, that's a whole other story. I am talking about the SDK, from C.
Yeh OK, I only use Arduino IDE and C++ . have not looked at SDK as such and won't unless I have to. Too much clutter in the head but I was trying to understand your post overall ,Thanks.
By FlyingHacker
#22952 tytower, Maybe if we knew exactly what you were trying to achieve we could be of more use.
PWN just makes a square wave with a particular duty cycle. It is usually a hack to avoid having to use a DAC. This is especially helpful with the ESP because you don't have a ton of pins to interface with a DAC (which pretty much need the number of pins as bits of resolution... or you use a shift register to write to the DAC pins from just three pins.). The DAC could be a real DAC or an r2r ladder DAC made up of resistors.
You can write your own software PWM if you need to (interrupt timer to switch pin on an off at particular intervals). Arduino's PWM, i.e. analogWrite(), seems to work in my limited testing. It wanted 10bit values 0-1023.
By tytower
#22955 I didn't find it on my machine (Puppy Linux) so a search gave me this below . I have no idea at this stage how this is used to drive a pin on an ESP8266 but I guess it will come to me .
Code: Select allpwm.h
Go to the documentation of this file.
00001 /*
00002     ChibiOS/RT - Copyright (C) 2006,2007,2008,2009,2010,
00003                  2011,2012,2013 Giovanni Di Sirio.
00004
00005     This file is part of ChibiOS/RT.
00006
00007     ChibiOS/RT is free software; you can redistribute it and/or modify
00008     it under the terms of the GNU General Public License as published by
00009     the Free Software Foundation; either version 3 of the License, or
00010     (at your option) any later version.
00011
00012     ChibiOS/RT is distributed in the hope that it will be useful,
00013     but WITHOUT ANY WARRANTY; without even the implied warranty of
00014     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
00015     GNU General Public License for more details.
00016
00017     You should have received a copy of the GNU General Public License
00018     along with this program.  If not, see <http://www.gnu.org/licenses/>.
00019
00020                                       ---
00021
00022     A special exception to the GPL can be applied should you wish to distribute
00023     a combined work that includes ChibiOS/RT, without being obliged to provide
00024     the source code for any proprietary components. See the file exception.txt
00025     for full details of how and when the exception can be applied.
00026 */
00027
00028 /**
00029  * @file    pwm.h
00030  * @brief   PWM Driver macros and structures.
00031  *
00032  * @addtogroup PWM
00033  * @{
00034  */
00035
00036 #ifndef _PWM_H_
00037 #define _PWM_H_
00038
00039 #if HAL_USE_PWM || defined(__DOXYGEN__)
00040
00041 /*===========================================================================*/
00042 /* Driver constants.                                                         */
00043 /*===========================================================================*/
00044
00045 /**
00046  * @name    PWM output mode macros
00047  * @{
00048  */
00049 /**
00050  * @brief   Standard output modes mask.
00051  */
00052 #define PWM_OUTPUT_MASK                         0x0F
00053
00054 /**
00055  * @brief   Output not driven, callback only.
00056  */
00057 #define PWM_OUTPUT_DISABLED                     0x00
00058
00059 /**
00060  * @brief   Positive PWM logic, active is logic level one.
00061  */
00062 #define PWM_OUTPUT_ACTIVE_HIGH                  0x01
00063
00064 /**
00065  * @brief   Inverse PWM logic, active is logic level zero.
00066  */
00067 #define PWM_OUTPUT_ACTIVE_LOW                   0x02
00068 /** @} */
00069
00070 /*===========================================================================*/
00071 /* Driver pre-compile time settings.                                         */
00072 /*===========================================================================*/
00073
00074 /*===========================================================================*/
00075 /* Derived constants and error checks.                                       */
00076 /*===========================================================================*/
00077
00078 /*===========================================================================*/
00079 /* Driver data structures and types.                                         */
00080 /*===========================================================================*/
00081
00082 /**
00083  * @brief   Driver state machine possible states.
00084  */
00085 typedef enum {
00086   PWM_UNINIT = 0,                   /**< Not initialized.                   */
00087   PWM_STOP = 1,                     /**< Stopped.                           */
00088   PWM_READY = 2,                    /**< Ready.                             */
00089 } pwmstate_t;
00090
00091 /**
00092  * @brief   Type of a structure representing a PWM driver.
00093  */
00094 typedef struct PWMDriver PWMDriver;
00095
00096 /**
00097  * @brief   PWM notification callback type.
00098  *
00099  * @param[in] pwmp      pointer to a @p PWMDriver object
00100  */
00101 typedef void (*pwmcallback_t)(PWMDriver *pwmp);
00102
00103 #include "pwm_lld.h"
00104
00105 /*===========================================================================*/
00106 /* Driver macros.                                                            */
00107 /*===========================================================================*/
00108
00109 /**
00110  * @name    PWM duty cycle conversion
00111  * @{
00112  */
00113 /**
00114  * @brief   Converts from fraction to pulse width.
00115  * @note    Be careful with rounding errors, this is integer math not magic.
00116  *          You can specify tenths of thousandth but make sure you have the
00117  *          proper hardware resolution by carefully choosing the clock source
00118  *          and prescaler settings, see @p PWM_COMPUTE_PSC.
00119  *
00120  * @param[in] pwmp      pointer to a @p PWMDriver object
00121  * @param[in] denominator denominator of the fraction
00122  * @param[in] numerator numerator of the fraction
00123  * @return              The pulse width to be passed to @p pwmEnableChannel().
00124  *
00125  * @api
00126  */
00127 #define PWM_FRACTION_TO_WIDTH(pwmp, denominator, numerator)                 \
00128   ((pwmcnt_t)((((pwmcnt_t)(pwmp)->period) *                                 \
00129                (pwmcnt_t)(numerator)) / (pwmcnt_t)(denominator)))
00130
00131 /**
00132  * @brief   Converts from degrees to pulse width.
00133  * @note    Be careful with rounding errors, this is integer math not magic.
00134  *          You can specify hundredths of degrees but make sure you have the
00135  *          proper hardware resolution by carefully choosing the clock source
00136  *          and prescaler settings, see @p PWM_COMPUTE_PSC.
00137  *
00138  * @param[in] pwmp      pointer to a @p PWMDriver object
00139  * @param[in] degrees   degrees as an integer between 0 and 36000
00140  * @return              The pulse width to be passed to @p pwmEnableChannel().
00141  *
00142  * @api
00143  */
00144 #define PWM_DEGREES_TO_WIDTH(pwmp, degrees)                                 \
00145   PWM_FRACTION_TO_WIDTH(pwmp, 36000, degrees)
00146
00147 /**
00148  * @brief   Converts from percentage to pulse width.
00149  * @note    Be careful with rounding errors, this is integer math not magic.
00150  *          You can specify tenths of thousandth but make sure you have the
00151  *          proper hardware resolution by carefully choosing the clock source
00152  *          and prescaler settings, see @p PWM_COMPUTE_PSC.
00153  *
00154  * @param[in] pwmp      pointer to a @p PWMDriver object
00155  * @param[in] percentage percentage as an integer between 0 and 10000
00156  * @return              The pulse width to be passed to @p pwmEnableChannel().
00157  *
00158  * @api
00159  */
00160 #define PWM_PERCENTAGE_TO_WIDTH(pwmp, percentage)                           \
00161   PWM_FRACTION_TO_WIDTH(pwmp, 10000, percentage)
00162 /** @} */
00163
00164 /**
00165  * @name    Macro Functions
00166  * @{
00167  */
00168 /**
00169  * @brief   Changes the period the PWM peripheral.
00170  * @details This function changes the period of a PWM unit that has already
00171  *          been activated using @p pwmStart().
00172  * @pre     The PWM unit must have been activated using @p pwmStart().
00173  * @post    The PWM unit period is changed to the new value.
00174  * @note    If a period is specified that is shorter than the pulse width
00175  *          programmed in one of the channels then the behavior is not
00176  *          guaranteed.
00177  *
00178  * @param[in] pwmp      pointer to a @p PWMDriver object
00179  * @param[in] value     new cycle time in ticks
00180  *
00181  * @iclass
00182  */
00183 #define pwmChangePeriodI(pwmp, value) {                                     \
00184   (pwmp)->period = (value);                                                 \
00185   pwm_lld_change_period(pwmp, value);                                       \
00186 }
00187
00188 /**
00189  * @brief   Enables a PWM channel.
00190  * @pre     The PWM unit must have been activated using @p pwmStart().
00191  * @post    The channel is active using the specified configuration.
00192  * @note    Depending on the hardware implementation this function has
00193  *          effect starting on the next cycle (recommended implementation)
00194  *          or immediately (fallback implementation).
00195  *
00196  * @param[in] pwmp      pointer to a @p PWMDriver object
00197  * @param[in] channel   PWM channel identifier (0...PWM_CHANNELS-1)
00198  * @param[in] width     PWM pulse width as clock pulses number
00199  *
00200  * @iclass
00201  */
00202 #define pwmEnableChannelI(pwmp, channel, width)                             \
00203   pwm_lld_enable_channel(pwmp, channel, width)
00204
00205 /**
00206  * @brief   Disables a PWM channel.
00207  * @pre     The PWM unit must have been activated using @p pwmStart().
00208  * @post    The channel is disabled and its output line returned to the
00209  *          idle state.
00210  * @note    Depending on the hardware implementation this function has
00211  *          effect starting on the next cycle (recommended implementation)
00212  *          or immediately (fallback implementation).
00213  *
00214  * @param[in] pwmp      pointer to a @p PWMDriver object
00215  * @param[in] channel   PWM channel identifier (0...PWM_CHANNELS-1)
00216  *
00217  * @iclass
00218  */
00219 #define pwmDisableChannelI(pwmp, channel)                                   \
00220   pwm_lld_disable_channel(pwmp, channel)
00221
00222 /**
00223  * @brief   Returns a PWM channel status.
00224  * @pre     The PWM unit must have been activated using @p pwmStart().
00225  *
00226  * @param[in] pwmp      pointer to a @p PWMDriver object
00227  * @param[in] channel   PWM channel identifier (0...PWM_CHANNELS-1)
00228  *
00229  * @iclass
00230  */
00231 #define pwmIsChannelEnabledI(pwmp, channel)                                 \
00232   pwm_lld_is_channel_enabled(pwmp, channel)
00233 /** @} */
00234
00235 /*===========================================================================*/
00236 /* External declarations.                                                    */
00237 /*===========================================================================*/
00238
00239 #ifdef __cplusplus
00240 extern "C" {
00241 #endif
00242   void pwmInit(void);
00243   void pwmObjectInit(PWMDriver *pwmp);
00244   void pwmStart(PWMDriver *pwmp, const PWMConfig *config);
00245   void pwmStop(PWMDriver *pwmp);
00246   void pwmChangePeriod(PWMDriver *pwmp, pwmcnt_t period);
00247   void pwmEnableChannel(PWMDriver *pwmp,
00248                         pwmchannel_t channel,
00249                         pwmcnt_t width);
00250   void pwmDisableChannel(PWMDriver *pwmp, pwmchannel_t channel);
00251 #ifdef __cplusplus
00252 }
00253 #endif
00254
00255 #endif /* HAL_USE_PWM */
00256
00257 #endif /* _PWM_H_ */
00258
00259 /** @} */
    pwm.h
    Get ChibiOS/RT embedded RTOS at SourceForge.net. Fast, secure and Free Open Source software downloads
