By Jabberwock
#29703 For some time I have been using my ESP2866-1 with a specific sketch from Arduino IDE, so admittedly my flashing sikills got rusty... Still, I cannot figure out what I am doing wrong.
My current sketch is set to connect to my WiFi and react to specific commands - it provides feedback both on the HTTP page and through serial communication. It does both - that is how I know both that the module is working and that the serial communication is working. So, if I am correct, the only thing needed to start flashing is to close the serial comm window, pull GPIO0 to GND, reset the module and start flashing with esp_flasher... The problem is that it does not work - esp_flasher outputs "Failed to connect". What am I missing here?
By Jabberwock
#29915 I have used my Arduino UNO as a TTL connector in case my other one was not working properly and it is exactly the same: ESP8266 happily communicates with me over serial, just like prescribed in its current firmware, but refuses to communicate when I try to update the firmware.
Pulling GPIO0 to ground before startup does make a difference, as ESP does not run my old program then...
