Re: Unable to Flash ESP-01
Posted:
Tue Oct 13, 2015 3:22 pm
by xtal
If you are using the FT232RL usb adapter, I would highly suspect it. I had 10 of the units, only 2 out of the 10 would load flash reliably. I switched to a prolific style [ that was crystal controlled] no more issues, The Ft232 appears to have problems with long transfers, short transfers worked fine.
good luck ......
Posted:
Tue Oct 13, 2015 3:36 pm
by Agentsmithers
xtal wrote:If you are using the FT232RL usb adapter, I would highly suspect it. I had 10 of the units, only 2 out of the 10 would load flash reliably. I switched to a prolific style [ that was crystal controlled] no more issues, The Ft232 appears to have problems with long transfers, short transfers worked fine.
good luck ......
Can you send over a link and Ill order one today and try it out.
Posted:
Tue Oct 13, 2015 3:40 pm
by eduperez
Agentsmithers wrote:Can you send over a link and Ill order one today and try it out.
I am currently using this one:
http://www.ebay.com/itm/321546809495
Posted:
Tue Oct 13, 2015 3:47 pm
by Agentsmithers
Agentsmithers wrote:xtal wrote:If you are using the FT232RL usb adapter, I would highly suspect it. I had 10 of the units, only 2 out of the 10 would load flash reliably. I switched to a prolific style [ that was crystal controlled] no more issues, The Ft232 appears to have problems with long transfers, short transfers worked fine.
good luck ......
I think I might have a CP2102 at home. I think it only pushes out 5v?
That one seems it does 3.3v though? Does it require you to soldier two joins together to bring down the voltage?
