By bbx10node
#31581 Have you seen this?
https://www.adafruit.com/products/2745
This 3.3V Buck Converter Breakout board is great for supplying power to low voltage circuits from a single Li-Ion cell battery or USB power. This chip provides up to 600-mA load current across the entire input voltage range of 3.5 to 5.5V.
By Kennetht
#31591 Using that Lipo charger board and placing an ams 1117-3 behind it wil not work. The 1117 needs an input voltage of min. output voltage + 1.5V.
As the max voltage is 4.25V on the board this is lower then the needed 4.8V.
You need to place two lipo's in series.
But the charger boards cannot be linked.
By al1fch
#31612 Tested OK with TPS63060 on his adjustable step up/step down regulator
https://www.pololu.com/product/2118/resources
Ok with input voltage down to 2.8V,
ESP-01 sending datas to TingSpeak every minute (no deep-sleep).
Not yet tested with ESP-12 awake from deep-sleep
